How many cam cover bolts are on a 420SEL? I have removed four from each; there appear to be no more. I've tried hitting the tops and sides of the covers with a rubber mallet, but it's -10C outside, and I don't want them to shatter.
Thank you
CH4S Admin , Outstanding Contributor
Welcome, to take advantage of all the forum features, please re visit the 'Welcome to the Forum' tutorial sticky on top of the W126 page, as well as the two DIY stickies.
It will show how to search the forum, and even has a link to the Russian MB site where you can run a VIN#. The forum archive has a wealth of information.
Cheers
A search with 'Valve cover bolt washers' got me http://www.benzworld.org/forums/search.php?searchid=2295840
and http://www.benzworld.org/forums/w126-s-se-sec-sel-sd-sdl-class/1255652-timing-chain-sliding-rail-3-guides.html?highlight=Valve+cover+bolt+washers
= 4 bolts per cover
Thank you
See my post for # of bolts. You'll need new copper crush washers and valve cover gaskets, and not too much torque. Often leaks are caused by too much torque squishing the gaskets.
Thank you
Someone may have stuck the valve cover on with silicone or the like, or it could be binding on air plumbing around the top of the covers.
On my 500, I had to wiggle them around to get them free of the air injection plumbing.
Best of luck!
