1990 W124 300TE-24 3.4 AMG, 1991 W126 300SEL
Hi
My speedo is out by +10 to +18km/hr. more at higher speed. Anybody had done this job before? BTW I am running a set of standard wheels and tires.
Raf
1987 Mercedes 300e
hmm, i would like to know to. i saw in another topic about wheels that they can just calibrate the speedometer... i haven't heard of it but ii would like to know because i have a feeling that i am going too fast.. mine says im going 40 mph down the street but it feels like high 40's... like 48ish. ideas?
1987 Mercedes 300e
too bad i can't edit the post.. i am driving on stock 16 inch rims seen here...
http://members.cardomain.com/cali_driver
the tires on them are Yokohoma's YK420 p215/60R15 93H
when driving i feel like i am going too fast or that the speedometer is reading too low.. any ideas??
2004 SL55 AMG
[8D]
I assume Benzes have electronic guts in the speedometer, which require re-programming to calibrate. Basically, a numeric constant value stored in digital memory needs to be changed to accomodate the geometry change caused by a larger/smaller diameter wheel or tire. I don't know if the programming device from Dashpro will do the job or not, but it gives you an idea of what's needed.
http://www.dashpro.com/prog.html
Cheers!
Dave
