2002 slk32 amg
I am having a problem with a musty mildew smell after it rains. I can't find any dampness or wet areas anywhere. If I leave the top down it clears out but I can t find where it is coming from.
2002 SLK, 2008 C300, 2010 ML350
I had that issue on my other benz: a C300. Basically water is seeping in through the cowl. The dealer fixed mine because at the time it was under warranty. But I was told then to run the ac if it should our to help eliminate the moisture.
If you suspect the cabin filter of being contaminated and don't want to renew it, you can wash it - spray with detergent - rinse and leave to dry on cloth on an old newspaper overnight - this will wick out the moisture as it will not pass air if wet
Oberoi
2001 SLK320
I would still suggest replacing it with a new one - preferably a charcoal activated / particulate filter. That way whatever odor that might pass through will get trapped within the filter.
