C43, Ferrari Daytona
Does anyone know of a way to turn-off the traction control of a '98 C43? The ASR/ESP switch only deactivates the "yaw" controls, not traction.
CLK55/G500/E55/ML55/etc.
My understanding is that using the ESP switch does not deactivate the yaw controls, but only changes the way the system tries to intervene.
A few methods (I think if any of ESP/BAS/ABS are deactivated, all of them are deactivated... not sure though, but it seems to be the case on my C43):
1) Remove the associated fuses.
2) Disconnect a speed sensor at the wheels (there are connectors in the wheelwells)
3) Disconnect the wires going to the steering wheel angle sensor (may not deactivate ASR or ABS, but I think it does)
Either of those should cause an error and the computer will deactivate the offending functions.
-s-
C43
Thanks for the reply. Do you know if unplugging any of these will create any problem with operation otherwise?
