1 - 12 of 12 Posts
A lot of performance cars!
I picked up a C43 with a bad transmission. Instead of wasting money rebuilding the Auto I decided to convert it to Standard. What I have found out is the M112 V6 has the same bellhousing pattern as the M113. So I should be able to use a 6-Speed trans from the SLK320 or Chrylser Crossfire. I will just have to research about the flywheel and clutch. Finding the pedals was no problem from Germany, I was able to order 2 sets from a friend so I can convert my C230 later. Has there been any other work done on this before?
99' C43 AMG "T Rex", Ultima Sports Can-Am (in build)
There has been an extensive discussion about this option on the Other Forum. Seems there will be big problems. I also see electronic ones with impossible dialogue between the ECU and the box.
I know the ASR and the speedo will be a challenge. Could you pass me the link to that forum? Thanks
1998 C43
you can get the transmission brand new from parts.com for $4002 (pn - 2112606600). doesnt seem too bad.
99 C280
You could try contacting LantanaTX on crossfire forums. He has a v8 crossfire, and has some knowledge of the ECU issues you may face.
Anyone here from Germany? I need a source for the Clutch & Brake Pedal Assembly & Clutch Master from a Euro W202
1 - 12 of 12 Posts
