1 - 11 of 11 Posts
I've got a C36 AMG with the 4 gear automatic transmission.
I'm not an expert in the Mercedes world ;-)
but when I see some pictures of the
C36 4 gears transmission
C43 5 gears transmission
E55 AMG 5 gears transmission
they look physically similar, and I did not see difference concerning the coupling with the engine
so my question is :
is it possible to fit a C43 or E55AMG gearbox on a C36
I assume the gearbox leveler + gearbox ECU need to be change too
thanks for your help
Discussion Starter #2
I find a good link :
722.6 ZF transmission application
so the c36 5 gears use the 722.629 gearbox
it sames the same gearbox as for the E420 W210
but bell housing is different
in my mind, changing bellhousing is not possible cause not possible
but I find a post on this forum, and the guy tell it is possible
I think I'm not the first one who want to change the old 4 gears tranny for a modern one ...?
98c230 & 98c43
Why would you want the 722.631? It's prone to failure easily after 60,000 miles, and is not anywhere close to what one would call bulletproof. your c36 4-speed on the other hand is a different story.
in fact if I find the housing converter from the 722.629 (C36 5 gears)
I can fit any 722.6 gearbox
like an E50 or E55 AMG
why I like to change :
have a gearbox more modern
I do not like the actual with is not autoadaptative
when I drive, I can quick down it take 2 secs or more
and if after that I depress a little the accelerator, tranny take the upper gear
I dislike it
it's not sportly ;-)
so for arround 1500$ : gearbox 5 gear + shifter + ECU, I can change everything
the 722.6 problem is an oil problem with bad gasket
you can fix the problem ;-)
1997 C36
Don't do it. 1997 C36 went to 5 gears and adaptive tranny and I just spent $5,000 on a new one after only 130,000mi. (which I guess is pretty good) but other mercedes I have owned lasted 200K+mi. The dealer wanted $7,300 by the way. I looked into putting a 1995 C36 AMG 4 gear tranny instead but then I was told I needed to change out the ECU and the Transmission computer too. Also, the Torque converter wasn't the same. Was cheaper just to replace with the OEM 5 Gear and hope to get to 100,000+ miles again.
1995 C36 AMG, 1998 C43 AMG
What! :eek:
Dude if your going to go to all the trouble of changing out the tranny/ecu/bellhousing etc... at LEAST make us all jealous and try and get one of the TIPTRONIC 5 speeds from the 00' C43! :thumbsup:
I already find :
- the gear lever (I buy it)
the C36 5 gear gearbox (autotransmission sell it) so no bellhousing to change ... it's the good model
- I need to check to see if oil pipe are the same
- I find many ECU transmission not expensive (80-140$) it sames different versione are because you can have different differential ratio 3.07 3.27 ....
- I need to check for the transmission hardness (gear lever as not the same connector (4 gear or 5 gear)
can someone explain me how the autoadatative gearbox takes RPM and speed to change gear
connexion with ECU ??
the 4 gear transmission is mecanical with a wire on the throttle body to check acceleration
but with the 5 gear ?
C36 AMG 1995
Hello All
Stick with the 4 speed vacuum controlled gearbox, slightly less performatic than the 5 speed ecu controlled unit. (But alot alot stronger) Talk to merc specialist mechanics and they will tell you about the 5 speed box failure rate.
My four speed box C36 is on 176000 miles, trans fluid change every 30000 miles>
1997 C36
I was told by a specialist that I would need a new ECU programmed for only 4 gears and a new Transmission computer since the one in my 1997 5 speed is adaptive and the old 4 speeds are not. Way too expensive at one shot. Cheapest to get a rebuilt OEM 5 speed for another 100K+ and keep everything the same.
96 C36, 87 Turbo'd 190E 2.3-16, 86 SC'd 190E 2.3-16, Brabus'd C32
this would be the most pointless couple grand ever spent. The 4 speed is bulletproof, the 5 speed is not and its not more "sporty" If you are going to spend any money on the tranny at all, go 190E 16V 5 speed getrag manual tranny.
1 - 11 of 11 Posts
