can someone tell me where the ecu is on a 95 c36 rhd.
Cheers, Nik
If you opened the hood/bonnet
you will find a black plastic covering in front of driver side (Rigth hand drive) with a triangle like shape.
Remove this cover, and you should see the ECU cover underneath.
(basically it's located on the opposite side of the Fuse Box under the hood/bonnet)
Regardz,
J Irwan
