1 - 9 of 9 Posts
I like to know with toe setting you put for the front and the rear
actually toe in :
front : 0°15'
rear : 0°20'
you put more ? less ?
I was thinking about
you should apply load to the front wheel :
the front of the front wheel (like pushing for toe in)
the rear of the front wheel (like pushing for toe out)
I apply load on tyre itself or do a tools to apply load on the wheel
I try to find how looks like the load bar (a picture) and found nothing
1996 Silver C36
As I interpret the Mercedes document, I think that the front wheels should have a spread load (ie, forward half of wheel load outwards) during set-up as would be experienced under front wheel drag loads during driving and braking.
The rear wheels are set under zero load condition. (Engine Acceleration loads are inwards and braking loads are outwards).
how can you check those informations (not clear for me) :
ball joint position : 31.0 +- 1.5mm
permissible height deviation in ball joint position between pitman arm and idler arm : 2mm
help appreciate
1 - 9 of 9 Posts
