Just a quick observation about my experiience with MB Traction Control.<p>I have a 2001 SLK 320. There is an amber triangular indicator light in the center of the speedo to alert the driver that traction control is in the process of intervening. I'm not sure if the C series has this light or not.<p>My experience has been that hard acceleration from a standstill will almost always cause the traction control to kick in. When TC is defeated and hard acceleration is attempted from a standstill, watch-out! She can really break loose! When the traction control does intervene, the engine looses power momentarily. <p>I have had the same experience with attempting to make a quick start to get into traffic and had that disconcerting power-loss make it a hair raising experience. I have on the other hand defeated the traction control and attempted a similar manuver and almost lost it when the rear-end broke loose and it was all I could do to keep her out of the ditch!<p>I've acclimated to the traction control now, and have no complaints. I think in low traction situations my SLK performs like a champ. Thanks MB!<p>2001 SLK 320 <br>Glacier White <br>Charcoal Leather <br>SP1 Sport Package<p>: Hi, and thanks for your input.<p>> I can¦t comment on the BMW, because I don¦t know if it is a manual or automatic.<p><p>It's an automatic.<p>>>>1. When doing a standing start with an automatic, much of the energy goes into reving up the engine. So you first feel less accelaration until the engine gets to the target rev. This is not ver likely the problem, because it shouldn¦t be more noticable<p>Right.<p><br>>>2. Modern cars usually have some traction control system. The C320 uses ESP. This has the possibility to reduce torque when starting. Normally it should only be active when pushing the throttle very hard. <p><br>This might be the reason<p>Ah yes.. it might well.<p>> to test it you have to use some kind of CAN device, to check if ESP reduces the torque of the engine.<p>OK, that gives me something to look at then.<p><br>>>><p>3The torque converter [snip]<br>This applies only to the first moment of starting from stand<p>Also possible then, as it is only the first moment.<p>Thanks for the input.<p>Mike<p><p>
