Can I instal HID on C320 ?<br> I instal K2 HID but it did not work when the engine is on. It worked when the engine is off.<br> The HID kit has 2 ballast and 2 starter. what does starter do? is the starter causes the problem<br>
Discussion Starter #2
Do you get Low Beam bulb malfunctions on the MFD? If so the computer is expecting a 55w load seeing the ~35w load of the HIDs and shutting them off. From what I understand the computer can be set to accept the 35w load but the dealer must do this.<br>
<br>
Hope this helps.
