S500v 4M. '03 - S600 V12 '98 (Sold) - E320 4M. '99 - E430 4M. '01 - CLK320 conv '04 - C32 AMG '04
Hi guys, I finished adjusting the supercharger clutch on my C32, it had the factory 4 shims (2 thick ones and 2 thin ones) and kept one thick and one thin.
It went from 0,6mm (++0,025 in) down to 0,25 (0,010 in) before reinstalling the belt.
Gap specs should be 0,25-0,30mm (0,010 to 0,012 in) on the M112k (different from the M113k).
The problem came when the belt got installed:
1st- supercharger no longer kicks in (tested the magnet with external 12v, it still clicks and works and grabs the supercharger when the engine is on and given 12v)
2nd- The gap with the Belt on is pretty weird, have a look at these picture:
0,006 on the right
0,011 center
0,015 on the left
Noticed there was a slight play in the supercharger when i have the clutch off, but I didn't expect the clutch and its shaft to twist and be closer on one side more than the other.
Am I the only one? anything I might have done wrong?
What are you gaps with the belt on? Could any of you look it up with the belt on please?
0,006 on the right
0,011 center
0,015 on the left
