Anyone having lifter/valve lash noise at starting at 2000 - 3000 rpm? I have a noise that sounds like a lifter bleeding down at rpm - goes away below 2000 rpm. <br>
<br>
can you describe the sound? i'm not sure if i have the same problem. (more)
the sound that i'm getting is a flapping sound, which i swore was not there until recently.<br> <br> not sure if that's normal or not. feel silly to bring in my car for every unfamiliar sound i hear. i've never had a supercharged car, so it's hard to say!<br> <br> thanks.<br>
The sound starts at about 2500 rpm. Sounds like maladjusted valve lash or colapsing hydraulic lifter. Once started the 'tapping' sound stays noticable until revs drop below 2500 where it is once again quite.<br> <br> I also felt silly - but I brought it to the dealer anyway. They said after listening to it that it was a characteristic sound of the roller cam in C32 engine. Upon listning more closely to the sound I can imagine that to be the source but - I'm not 100% sure I beleve it.<br> <br> MB Tech also said it would get more pronouced as the engine breaks in. Well at least it will more constant then - not sharply clattering in at 2500!<br> <br> I'll let everyone know if the break in results in more or less noise.<br> <br>
Car: C32 AMG
Symptoms: Starter would not turnover or the solenoid would not engage.
Diagnosis: I checked all the voltage and found out the wire going from Starter relay on passenger side engine compartment to the Starter solenoid isn't sending voltage when key is turned to start position. It's...
So my 2002 C32 - 138K miles - jet is having some issues.
Couple issues - it idles oddly at stop lights and has for some time. Its just an annoying 'bobble' that should not be there. Have yet to put my finger in exactly what is causing it.
Recently changed the fuel filter. Changed...
So I owned this 2002 C32 for about 12 years and sold it to a co-worker about 3 years ago and a few weeks ago the transmission failed due to a failed radiator - coolant in the trans.
He is choosing not to repair it and would like to sell it as is, and I said I'd try and help. I'd buy it back...
I have searched, I see threads but I never see one that says they resolved the issue without taking to stealership. Our c32 was running perfect last night, went to leave this morning and turns over but doesn't start. Frst thing I thought was cps, replaced, still nothing. pulled the cover off the...
Hello,
I'm the proud owner of a 2003 C32 AMG Orion Blue color with 118k miles on it, very well kept interior and mechanically. The outside has few bubble spots that i was going to restore but due to the paint of the car being very rare, i thought i'd see if i should sell the car or repair the...
