1 - 1 of 1 Posts
I need some help interpreting the problem. My car went into limp mode (check engine light went on) and idle is unstable (jumping from 1000 - 2000rpm). Goes 20mph and then jerks. Went to the dealer and got the following codes:
2002 C32
P2407 (ETC)
P2000 (ESM)
P2032-008 (Throttle valve actual value pot: line mixed up P0120)
P202E-008 (Throttle valve actuator: line mixed up/positioner fault P0120)
P20D4 (The load limit is active)
P203B (Fault of function monitor in electronic accelerator P0221)
P2050 (Misfiring P0300)
P2051 (Misfire cyl 1 P0301)
P2052 (Misfire cyl 4 P0304)
P2053 (Misfire cyl 3 P0303)
P2043 (Misfiring P0300)
P2044 (Misfire cyl 1 P0301)
My guess is that the throttle actuator went out, but could it be the MAS instead/as well? Any suggestions would be greatly appreciated. Thanks.
1 - 1 of 1 Posts
