So I have driven 30 K on this AMG as pussy. I only drop into automanual when I want some performance. It is such a waste. The car isn't as fun as when I bought it.
It is not like punching and having it shift at red line. I have changed the yaw and the brake ABS box but I am not sure where else to look to overcome the issue. It runs like a tame car with out the Supercharger. I had someone check the wheel sensors with the Mercedez scanner but he said they were fine.
I the winter, when it is cold it sometimes goes back to normal and no ESP sometimes for an hour and that puts a grin on my face.
Please help me solve this problem.
I haven't driven the car in about a year. 113,000 Miles. However I went out yesterday and it seem if I only went about 1/3 throttle I could accelerate to freeway speed without hitting ESP, For the first time ever, whenever I floored it, I got the ESP and BAS {?} code. I would pull over and restart the car and with light pedal I could get out of 2nd and hit higher speeds without the 2 codes until I hit the throttle heavy and bing them on.
2005 CLK55 AMG Coupe ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
never heard of that! Is that something I can do myself?
Yes ,,I don't know if it will fix your problem but your transmission learns shifting points over time and sometimes benefits from a reset.
Sit in the car everything off,,doors closed.
Key to ignition
Foot to the floor,past switch and hold down for 15 seconds.
Accelerator still down , turn key to off.
then slowly lift foot off.
Sit and wait for 2 minutes and 20 seconds,
Remove the key and exit the car.
Wait 5 mins .
When you drive the car after that the transmission will relearn your driving style and shift accordingly.
