Car model: C300
Model year: 2008
W204
My driver seat backrest control using the seat switch stopped working in one direction only. I can move the seat forward and back, adjust seat height up and down, however, I can only move the backrest so that it leans further back (I cannot make it lean forward using the switch).
Can someone post the wiring diagram for a driver side switch for a C300, year 2008 (W204)? (with no seat memory option)
Also, does the switch that is on the side of the passenger seat directly control the motors, or is there another control module that the switch connects to, and that control module then connects to the motor? I do not have the seat memory option in my car, so it would be great if someone could confirm this question. Obviously the motor works, since the reverse movement just means a reverse polarity on the same motor.
I will check the fuses next, but I suspect they will be fine, since all of the functions (except for one) work. The fuse numbers for the front seat adjustment are: 2, 3, 44, 45, 116, 126
Also, can someone confirm if I have to remove the seat to replace the switch (in other words, is it accessed from below the seat) or does the plastic molding on the side of the seat need to be removed to uninstall and replace the switch.
Model year: 2008
W204
