sup folks! can anyone tell me what is the <br> stock revv limit on a 96 c280?? the tach says<br> 6500rpm? but seems weird how the engine cuts @<br> 5500rpm?? anyone with same problem?? I have changed the fuel filter to a c43 one. replaced plugs....still chuggz @5500rpm!
Re: c280 stock redline....RAUL
do u have any idea what might cause it to <br> cut at 5500rpm? <br> also yours goes up to 6000rpm does it shift<br> smoothly right at that point? or do u have to ease on the pedal a little?
<ul><hr><i>Originally posted by BBOYAD</i><br><br><b>do u have any idea what might cause it to <br> cut at 5500rpm? <br> also yours goes up to 6000rpm does it shift<br> smoothly right at that point? or do u have to ease on the pedal a little?</b><hr></ul><br>
<br>
You have a in-line 6 C280 w/ a 4 spd auto, not a 5spd auto V-6.<br>
<br>
So the redline, and transmission are different.<br>
However, your car should still be shifting at 6400 with out much abruptness.
ya inline 6 w/4 auto. im thinking now it might be<br> the o2 sensor or clogged cat. do u know if there is any fuel/air adjustment screw on the throttle side like the old bmw's or mercedes??
