can anyone confirm if the c250 1997 has a maf? i,m having problems that point to the maf like not being able to kickdown after 50 mph and a loud heavy sound when trying to get past 2000 revs.also a vibration sometimes when ticking over. if it dont have a maf what does it have that does the same job?
'96 C220 n/a diesel
as far as i know, it doesnt have a MAF, it has cold air flow sensor, which doesnt do much apart from monitor the air temp to determine the rate of fuel, all it is is a sensor in the air intake pipe, about 4" up from the air box
yep i,ve seen that one. there is also one on the righthand side of the bulkhead with a rubber pipe going to the manifold. just wondered if they could be the cause of the problem i,m having?
