1 - 8 of 8 Posts
· Super Moderator
1986/1990 W126
Hello there, welcome to the forum to you.
To find your section check out this link below, hopefully you'll find your answers in the section for your car. All the best.
· CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
I have this issue too: C221500
Does anyone have an idea what it is?
Mercedes C250 AMG 2014
B1 Service on C250 and ESP module code C221500 did not clear. What is this and is it important?
I guess indicates failing or faulty Steering Angle Sensor cause C220500 is Internal fault with Steering Angle Sensor
Could also be bad ABS Module or fault in ESP or ECU wires / connectors or brake light switch or one of the huge 80 amp - 200 amp fuses in the front SAM module which is below that plastic positive + red slider thing in engine compartment near battery.
Might loose systems such as Cruise Control, Run Flat / Tyre Pressure Monitor, Eco Mode, Assist Plus and possibly even ABS.
Hi ! I am facing same issue now in my c220d. I see this error only when I run the diagnostics. Doesn’t show up on the dash though. Pls advice if you have found the solution. Thanks!
Welcome to the forum
To find the chassis / section for your car, please click FIND YOUR FORUM SECTION
Once you found your forum section, Complete your Profile to show the year and model of your car next to every one of your posts. Members are not likely to search for the one post the model of the car is mentioned.
FYI, the forum index is grouped according to chassis designation, usually a letter followed by 3 digits, and sections cover all engine versions the chassis came with.
The forum sections archives have a wealth of DIY / technical information.
When posting, you can also Search the forum archives of your chassis section via the 'Search Community' box on top..
The stickies on top of the 'Welcome' section will help to navigate the site.
1 - 8 of 8 Posts
