2005 C230 Kompressor.
I installed a new timing chain and when I removed the clamps and cranked it a few times to get the CR I found the cams offset by 20 degrees at the crank. i.e. the intake cam is dead center with the crank at TDC but the exhaust is off by 20 degrees at the crank. I tried to move the chain up one link, but it is too much and the cams are just off the same amount in the opposite direction. The manual states it should be 6 degrees max. Anyone know what I can do to fix this issue?
Thanks, but I have the service manual for my engine. The problem isn't procedural just the result of following the procedures...
I just wanted to make sure you were using the proper MBZ WIS instructions. Sometimes the 3rd party repair manuals aren't completely accurate. Were you able to properly align the cams with the tool (or a suitable substitute)?
Yes I could align the cams properly. Even moving the exhaust cam ±1 link it is still incorrect timing. The "perfect" position is in between links.
If you followed the instructions and it's still off, then I'm not sure what coudl be wrong. You did remove the exhaust cam gear, right (step 5)?
