ml350 elegance - c230 kompressor
Hi, sorry my inglish is not so perfect... i have a c230 kompressor coupe2005, and winter is comming, i will keep it in a garage for 4 or 5 months, what i have to do to keep it in good conditions?? how many gas i should put in the tank?? full?? no matters??? i should go to the garage to started somme times to keep the battery alife??? any other advice?? thanks alot :thumbsup:
Tyres up to about 40 psi - no more - (or better, on stands)
Full tank prevents moisture - add fuel stabiliser
Change oil to remove moisture in old oil - min. starts after that
New style of trickle charger far better than occasional starting - will only charge when needed and not overcharge (top up battery also)
Make sure coolant has been changed in the last 2-3 yrs to prevent corrosion (and freeze up in your location?)
If you do start the car, make sure it runs for at least 15 min to get fully hot (long idling is bad)
Clean and treat leather
Dryer sheets or dessicant container will keep moisture down in cabin
If mice are a possibility, cover all openings (leave a list for uncovering openings!!!)
Oberoi
