1 - 9 of 9 Posts
i have another problem programming the garage door opener controls. I have tried hittin the button on the receiver and running to the car and holding down that button and vice versa but neither one seems to work.......can anyone please help
thanks,
callen
2006 C280 4Matic
thanks,
callen
call the MB customer service # in your manual & they'll walk you through it step by step if you need to.
2004.5 C230 Kompressor Sport Sedan
Same thing happens to me. It said in the manual though it could have something to do with the garage opener and it not letting it be programed to it. I guess some type of coding blocker?
Thanks for your help, i actually kept looking around and found that
1. you hold down the #1 and #3 on the rearview mirror till the lites start blinking(about 20 seconds). this erases the previous codes.
2.Then you hold down the button on your remote and the button on the rearview mirror, this puts the rearview mirror button on the same frequency as you garage door opener. While holding down the buttons you will notice the lite flashing slowly and when its programmed to your remote it will flash really fast.
3.Next you program the rearview button with your opener receiver. On mine, I get someone in the car to hold the rearview button while i press the program button on the receiver and when it is programmed, the lite on my opener turns on.
I just did it and it worked.
thanks again
Johnson Controls Inc. | Programming and Operation
Thanks again!
I just managed to program my garage door using the rolling code method.
I have Liftmaster Professional (41D4674-10D). I managed to get a copy of the manual and they have instructions in there as well.
http://www.liftmaster.com/pdfdocs/114A3072.pdf
I reversed my car out, thinking that it has to be line of sight. I tried several times but nothing works.
I drove my car right under the control box, and opened my sun roof, and reached for the "Learn" button.
So within 30seconds I have to press button 2, 3 or 4, I use "3", somehow "2" did not work. Btw, I cleared all the memory by pressing 2 & 4 for 20sec.
While pressing "3" for like 2sec, look at the control box/motor unit, there is a light there, it will blink and once you see it, release button "2".
That's it. It's done.
C320 4matic
thanks again
This is the correct method and it worked on my c320.
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
There are two steps to programming a rilling code system. First is to teach the HomeLink button the frequency of the transmitter (Step 2 above), and the second is synchronizing the rolling codes with the opener (step 3 above). Note that step 1 (erasing the HomeLink) is optional, and only necessary if you want to start with a clean slate on the HomeLink.
Note that in step 3, most opener units have one button to preform two functions - synchronizing with a new transmitter, and erasing all previously sync'ed transmitters. On my system (Sears Craftsman), pressing the program button on the opener once briefly puts it into sync mode. It stays in sync mode for about a minute, which is usually plenty of time to step down off the ladder and then press the recently learned HomeLink button to sync it. Pressing and holding (for three seconds) the button on my opener causes it to erase all transmitter synchronizations, meaning that each one would then have to be re-sync'ed, one at a time.
1 - 9 of 9 Posts
