Hi all,<br> Does anybody has the specs of the new 2002 C230 Coupe engine specs? Like Bore and stroke...etc<br> <br> Thanks!
Discussion Starter #2
sorry no bore and stroke value.<br> IT IS M111 EVO ENGINE BLOCK.<br> IN LINE 4 CYLINDERS 2297CC<br> 145KW, OR 197HP AT 5500 RPM<br> MAX TORQUE 280NM/2500-5000 RPM<br> 0-100KM/H IN 8.1SEC,0-60MPH IN 7.8 SEC.
Engine 111<br>
Bore 3.58 in.<br>
Stroke 3.48 in.<br>
Total Piston Displacement 140.1 cu. in.<br>
Compression ratio 9.0:1<br>
SAE J1349 hp 192 hp/5500 rpm<br>
Max Torque J1349 207 ft. lb./2500 --4800 rpm<br>
Max engine speed 6200 rpm<br>
