Hey Gang -
My Battery light came on on the dash this morning on the way in, and disappears once I hit 3500-4000ish RPM, then comes back below that. I'm assuming Alternator as my battery isn't even 2 years old. Anyone else had this happen?
Thanks!
C
2000 C230 Kompressor Special Edition
mercedes benz c230 1998
That problem comes because the alternator doesn't work properly! Some months ago I change my alternator for the same problem you have.
Or sometimes you just have to change the voltage regulator,maybe that can be the solution.
Sent from my iPhone using Autoguide
2015 C300 4Matic, 1978 240D
Yeah that is probably the alternator. It could just be the belt slipping but you should try testing its output at idle.
