I have a 95 C220 w/30K mi. and having trouble start the engine when the engine warm, engine need to be turn over about 10-15 sec before it start. The car start up easily when the engine is cold. I brought the car to dealer, but they couldn't find anything wrong. Is this normal for this car? Any one out there having the same problem or could thing of anything wrong, please share you experience.
Check Coil
On gasoline engines, it is the symptom of bad ignition coil/coil pack. I would check the resistence of those units when the engine is hot (when it takes 15 seconds to crank and start; with the engine off, of course.) If the resistence is high, compared to when the engine is cold, you have bad coil(s).
