Hello can anyone help?
I have a 1995 C280 the rear windows work fine, the front ones dont.
The fuse keeps blowing that powers the front windows, the fuse is located in the boot.
I think it could be a bad earth, has anyone had this problem? How did you stop the fuse from blowing?
Discussion Starter #2
Hello problem is now fixed it was a faulty window control unit which is located on the right hand rear chassis, you need to remove the battery to see it.
They are several different units depending on your model, the C280 is parts number
202-820-42-26
