Hi Guys
Having searched the forum I've not found a answer to this and hoped someone has had or knows what the problem will be and can help.
There is one function for the seatbelt extender which does not work properly, it is the auto retraction feature when you clip the belt buckle in.
The extender will retract after 'timing out' for 30 seconds which is standard function. It is slightly annoying as obviously it should retract as soon as you plug the belt in.
This only affects one side and it is the only thing that does not work.
I assume somewhere a micro switch may be broken or a wire broken, has anyone tackled this issue, how did you fix it, what was involved in the job and how long should it take. Thanks a lot.
Could be, have you fixed one before, what's involved. Can the switch be replaced if broken?
Sorry, I did not see a link to a wiring diagram at the bottom of the post?
