C126 W126 Water Pump R & R DIY and Vacuum System Restoration
Hello Class! Today's topic is going to be the Removal and Re-installation of the Water Pump and the rejuvenation of the Vacuum system.
THIS DIY APPLIES ONLY TO THE 117 560 MOTOR AND DOES NOT APPLY TO THE 500 MOTOR. SEE SEPARATE DIY FOR THAT INSTRUCTION!
This started for me as Summer approached. I saw the temp coming up more and more everyday. Then three weeks ago I went up to see my good friends Bondavi and AzimuthAviation. On the way home up the Grapevine (a 6% grade) the started to climb up in temp to over 110C. I started to freak and pulled over near the mid point to rest it and then continues up to the top where I rested it again at the truck stop there while I ate. The rest of the way home was either flat of down hill so it did not really overheat much the rest of the way. Only uphill it had problems. T-stat? Fan Clutch?
In my DIY's I try to give an explanation of the system in question as far as theory goes, and I will attempt the same here. If you want to skip ahead go to the END OF THEORY in red.
The Mercedes Cooling System is a closed loop heat exchanger type system using a Propylene Glycol based coolant. A cooling system is designed to collect, transport and dissipate heat from a device, in this case our engine. Heat is of course generated by the constant explosions within the cylinders and of course a certain amount from the friction of the engine itself.
There are inner channels that both oil (For lubrication) and coolant (For cooling) to flow within the block and heads. We all know that water boils at 212 Degrees Fahrenheit at sea level and that is far too low a temperature to be in a metal block which could be a hundred degrees more. The water would quickly boil off even in a closed system. So we at a Propylene Glycol based additive (Coolant) to raise that boiling point much higher lever to keep "Boil off" to a point that when it evaps back from steam to a liquid, there is no or very little loos. You are always going to lose some and hence why we need to top it off from time to time.
We use Distilled water to introduce no additives or sediments that are naturally occurring or introduced into it at the purification plant. Distilled water we know has nothing in it but H2O atoms and nothing else so no corrosion can occur from it.
Coolant, or "Anti-Freeze" also has one other property that is important that we match the right coolant to our MB cooling systems. This may not seem important at fist blush, but as you will see from a metallurgy standpoint, it is most important. The coolant we will use will be Zerex G05 or MB coolant itself. They are one in the same and Zerex makes the coolant for MB.
Zerex is formulated for the types of metals in our engine and radiator. And Green and Orange or Pink coolants are designed for other makes, NOT Mercedes. Zerex is a little harder to find. I had to go to a NON-chain auto parts store that knows me and they said they would stock it for me as well as the Chevron Delo 400LE Motor Oil which we will cover at a later date.
Okay, so the Engine heats up and we need to get the engine cooler so we pump the water/glycol mix though it and the water heats up of course and we pump that out to the radiator. Well not exactly all the time. That is where the Thermostat comes in. The T-stat in our cars if you use the right one is a two stage affair. Up to 80C it remains closed to keep water within the block to warm it up. Once the engine is at 80C or so, it opens partially and lets some water through to the Radiator to cool some of it. Under heavy load such as a steep grade (Remember that 6%?) or with the A/C on, the engine will heat to 90C or more, then the T-stat opens to a point where the "Bypass" is blocked off and all of the coolant flows through the radiator.
There is a fan mounted to the front of the water pump driven by belts from the crank pulley and it will engage or disengage based on engine RPM. The faster the motor spins the clutch will disengage and let the natural speed of the Engine take over from there.
There is a single Electric fan on the outside which will kick in at 92C or, if you add a 1.1K ohm resistor as Jono points out, that will lower the kick on point to 80C or so. This provides extra ait flow through the radiator no matter the speed of the vehicle or engine. Mike Ramay wisely installed dual rear Electric fans to replace the WP fan since he lives in the desert and I may go the same route.
Hot water is also delivered to three other system in the vehicle to provide heat transfer on an "On Demand" basis and those are the Cabin heater of course, but also to the Windshield/Headlight washer bottle (That's the curly metel tubes in there) and the Windshield base heater. The Windshield/Headlight washer bottle is heater (People ask all the time "Why do you have headlight washer? Do they get that dirty?" The answer Roy or another pilot can easily answer: ICE They are to De-ice the headlights in the event of a severe storm. As any vehicle moves though a cold wet mass, ice will accumulate and decrease either visibility or lift. A bad thing in either case. (VERY BAD in the latter.. LOL))
So the Windshied is heated at the base with hot water from the engine and the Cabin heater and also the Waster bottle.
So the coolant flowing through the radiator is also adept at shedding the heat as well as the Radiator itself. The little fins this out the coolant and it flows down the tubes and the air passing through brings down the temperature and it flows back into the block and heats back up. Everything should work fine in a well designed system, but if any one component is out of whack, it throws the whole system off. If you have any leaks, coolant level dips, reducing the thermal efficiency of the remaining coolant and not transferring enough heat out of the block fast enough. The engine heats and starts to boil off the remaining coolant and you get steam into the system. Nice for a ships engine, not your car.
So clearly we need good hoses, clear of scale and no cracks of course. We need an un-blocked radiator with good flow. We need a working water pump to move the maximum amount of coolant through the entire engine to the Radiator. And we need a working thermostat to control that flow optimally.
If any of these components are bad, we could blow our motor.
END OF THEORY:
So the next morning I order a new Thermostat and all new hoses and they arrived from MB and I installed them. Well I think that the pressure of the new t-stat put pressure on the main bearing and made it blow because as soon as I did that, a leak was evident out of the bottom weep hole. PUMP GOING, GOING, GONE SHORTLY!
So I looked up a pump online and it was about $100.00 to $150.00 for an Aftermarket Pump. I consulted Jono (WHAT AN OUTSTANDING RESOURCE AND HELP HE HAS BEEN THANK YOU JONATHON!!!) and he was fairly clear that a factory pump was the way to go. So I called my dealer and he quoted me $460.00!!! Holy
[email protected] Batman! Then he said he would give it to me for $175! WAY TO GO MB of Valencia!
So I put the pump on order, quickly!... And I surveyed the rest of the Engine parts that I would replace. I knew I was having Vacuum issues like Charlie described, so taking a cue from him, I ordered all of the vacuum check valves and while I was at it I ordered the thermovalves on top of the engine from the EGR and the TB and I also ordered all of the color coded vacuum lines to match the factory. My Parts guy said that it is very hard to order because of limited availability. But I picked up 5 meters of each color so I will have plenty for both cars.
So the Plan:
R&R the Water Pump and all key components thereof;
Replacement of the Radiator with a Behr model with Reinforced necks;
Replacement of the Overflow tank and water level sensor.
R&R all of the key vacuum components and hard lines
Clean up as much of the Engine and bay as possible;
Possible replacement the hood pad first of the week;
Installation of a Mil-Spec 1.1K ohm resistor in the Fan Thermostat wiring to lower the "On" point to 80C from 90C (per Jono's recommendation);
Simple! Okay well if anyone has the proper documents, it's me! So I proceeded to study up on the procedures.
So here are pics of the related systems:
Here is the very front and you can see the front Electric Fan, the cheater Chinese Radiator and the top of the pump and Distributor at the top of the pic.
Moving back we can see the top of the pump, DIST, and the EGR Thermovalves and vacuum lines. 20 years of cooking next to the engine have left them completely brittle. If I even stare at one it breaks, let alone breath on one.
A closeup of the pump. If you are buying an OEM pump they will want an OEM pump back (MB is kinda funny about that!) and it MUST have the MB Tri-Star above the serial number like in this:
Look above the part number there and you will see the MB logo. It must have that logo:
I also, in the constant "restoration" on my car, wanted everything I replaced to look new so the old Brown OV Tank needed to go and I ran a new rubber hose through the fender when I did the side lights two weeks ago:
Also, I have a spare set of Valve Covers that when I was having the Air Cleaner top polished out, he said he could do my VC's so they are off being done. He quoted me $100.00 but it will take two weeks to get them back so they go on later. Also doing the PS pump top too. Should look pretty nice under there after:
All of this Vacuum stuff will be replaced.
