1 - 14 of 14 Posts
I've contemplated getting a tailgate filler panel for my truck and was having a look at the pictures in your gallery. It seems that the filler panel crease lines up perfectly on the right (looking from the back) but at the left the filler panel line sits a little below the bumper line. How well does it really line up with the older bumper?
· Member
'00 ML320 Elegance
RE: Tailgate filler panel
redeye - 2/1/2005 8:51 PM
It's really up to you to adjust how you want it to fit, but on the tailgate itself or by adjusting the height of the bumper.
Here's a pic of mine vs. a good friend's '03 ML500
2014 ML350 BlueTec
redeye - 2/1/2005 11:51 PM
l had a body shop install my tailgate panel....l think it is a welcome addition to the back...is it a perfect fit..No..but its pretty close....You can either, two way tape it, or have it screwed in, like l did.....A great "mod".....
ML320, ML430, E320
C-Rod, I think that you have a dual exhaust system. Could you tell me a little more about it please? Is it making a good sound? is it expensive?
Thanks man!
Discussion Starter · #6 ·
onesixthree - 2/3/2005 11:55 AM
it wont always line up because the bumper cover is attached to the frame and not the body. if your car is not level, it could look a bit off
I must say that I doubt flex/movement of the frame vs body would be enough to be visible in any gaps on the ML (maybe on a Dodge/GMC etc. [:)] ).
Discussion Starter · #9 ·
BTW, does anyone know what the part number is? I tried to explain to my local MB parts department over the phone, but they replied with a price of around $1000 (Canadian) so they must have misunderstood (I hope).
2014 ML350 BlueTec
ML_OWN - 2/3/2005 12:38 PM
Thanks man!
Hey "M".....lt is the SuperSprint Quad pipes, only one muffler..Pricey..a little, it cost me $525.00 American at the time.....Any louder??? not really...it still has the stock muffler....You can go to SuperSprint.com and check it out......l think it really finishes off the back of the ML...l'm sure "Lochs" and "Pize"..will agree.....
2020 MB GLE 450 4MATIC, 2015 BMW M4
RE: Tailgate filler
Just be sure you mechanically fasten it. I didn't want to drill holes in the tailgate, and used 3M Marine Grade double stick tape. It worked fine unitl I went skiing and at 20 degerees and 50 mph saw it blow off the back of the car! Cold did the adhesive in.
99ML320 (retired) C230 530xi 911-C4
redeye - 2/3/2005 9:30 PM
redeye, just go to www dot for_my_mercedes dot com
(remove the underscore)
Discussion Starter · #13 ·
roadsession - 2/3/2005 8:55 PM
I did but he seems almost reluctant to sell it, replying that it is a difficult install and a Mercedes part that must be painted without actually providing a delivery time or shipping estimate...
Discussion Starter · #14 ·
RE: Tailgate filler
GregW / Oregon - 2/3/2005 8:50 PM
Thanks for the heads-up. It's been known to get to 20 degrees up here, so I guess when (if) I do get this it's off to the bodyshop. Did you replace yours?
1 - 14 of 14 Posts
