In the 2002 C230 Coupe there are three cover lens for the interior cabin lights just in front of the rear view mirror. Following the instruction manual, I was able to open the big middle lens. How do I open up the 2 small lens to the side of the middle lens? I need to replace a bulb in there.
Discussion Starter #2
I believe you have to pull down the entire mounting and replace the bulb from the interior instead of doing it the way you did with the larger map light... which was going through the outside. Try using the instructions in your manual for opening the mounting when accessing the manual lever for opening the sunroof. It's pretty much the same process.
