It was a one owner car with 130k on it right now. Is there anything I should watch out for or look out for? It has the m112 engine I believe and I've heard mixed things about this car and particular engine. Any help would be great!
I see you have a w203 I had a 02 c240 and then a 02 cl500. The cl was a great car when the abc system worked and the reed valves didn't let water in through the hvac system and flooded 2 Sam units and a wiring harness lol. even though there was a class action lawsuit filed against mercedes the dealership told me to go kick rocks basically. However the 02 c240 was a overall fine car. Hoping the c320 will be okay as well. I'm just obsessed with mercedes.
2002 C240 Auto (Hijacked by criminals), Now I have a 2005 C200 Auto.
I have a 13 year old C240 with 270000kms on the clock. The 320 is just a larger engined version of the 2.6 liter 240. I would recommend this vehicle to anyone as long as it has a good service history. The 112 engine is virtually bullet-proof if it has been properly maintained and serviced.
The only problems I have had have been minor and not really expensive, but considering the age and mileage of the car, not unexpected.
Just stay away from the 2006-7 V6 and V8 models.
2005 CLK55 AMG Coupe ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
As per Provo,,320 is the same as 240 except longer stroke for more capacity and torque,very nice performance. Just all the same issues ie transmission/valeo radiator to be avoided.
Check the transmission changes all gears very smoothly,and get the fluid changed and pilot bushing changed asap if not already done.
