82 380SL 96 SL500 03 SL500
Dumb question... What glue would you use to reattach the button to the top of the shifter in a 129k?
It appears from the nut under it that it should be removable when necessary, and also appears to originally been attached with a thin foam tape.
So... I'm looking for an adhesive with that perfect balance of holding, but not tooooo well. :)
1998 SL500, Panoramic Roof, Factory Xenons, Black/Black/Black 2012 GLK350 Black/Beige
I used a little dab of 3M Black RTV Silicone adhesive with good success.
Moderator
SL55, 300SE, GL450, Daytona 955i
I got some clear rtv adhesive and will give it a try, making sure to not "overglue".
Thanks.
Sith Lord
72 280SE 88 560SEC 92 E500 6.0 95 SL320 14 GLK350
Make sure you thoroughly clean old residues. Else it will come back off.
