Hey everyone. I’m tackling removing the bushings from the LCAs on my 2001 E320 4matic wagon.
I read somewhere someone had used this general bearing/bushing set with success but I can’t figure out how to make a receiving cup match the collar (same diameter as the rubber) on the rear and I also understand one of the other bushings are pressed in as two pieces?
anyone with info on this job and perhaps any advice on how to use this tool set?
2634111
I was lucky enough to take them to a shop to have them pressed out.
Without a press I would have cut the old bushing out and use a bench vice to push the new ones in.
Good luck not to bend LCA.
Hey no worries, I got it figured out and I have a solution that I came up with that's gonna save everyone a ton of money and trouble. I did it on the driver side one and it literally popped the f out and I'm not kidding. The other two are simple, the fronts are chiseled punched out and the connection to the spring/wheel you can use the bushing/bearing set I bought.
I'm going to film the reasonably cheap tool I bought at Harbor Freight to pop that nasty rear (20 year old in my case) bushing out with ease on the passenger side and update the post here with a YouTube link.
(I'm not kidding, I was able to push that bushing out in two minutes like butter.)
