21 - 38 of 38 Posts
Discussion Starter #21
List updated 7/25:
gen II W124 drivers corner marker (clear/yellow) bosch $10
w124 passenger seat belt w/ tensioner from 87 300D $10
NEW w124/w201 rear shock absorbers (monroe/gabriel?) $75 pair
w124 sedan lorinser trunk spoiler $100
r107 hardtop interior handles grey $5
w140 near mint drivers side headlight lens w/ a broken clip (doesn't affect mounting) $30
87 300D/SDL Bosch ABS Module $5
005 545 0532 Cruise Control module $5
003 545 3832 190E ECU $5
NEW in box Bosch Oxygen Sensor for W124 $70
NOS wheel center cap 201 400 0425 $3
Leather owners manual pouch (came with W124s) $7
seat switch 002 820 5910 $3
w126 fuel pump relay 002 545 1605 (6k rpm) $3
seat switch 005 820 5610 $3
blinker/hazard relay 201 821 0047 $3
klima relay 002 545 1805 $3
NEW crank position sensor W124 015 545 2828 $70
klima relay 002 545 1305 $3
190e fuel pressure regulator $10
m103 fuel injectors (5) $10 for all
AC compressor relay KAE for 190E $3 (2001 replacement)
w126 parking brake shoe kit 126 420 0120 - $10
2 w124 horns $5
rear view mirror glass pass. side 201 810 1421 $5
w126 idle control valves 000 141 1225 and 000 141 1025 $5 each
r107 hard top side glass $20 for both sides
w124 front electric fan (single fan style) $10
190e passenger rear window motor with regulator $10
NOS replacement antenna mast 140 827 0001 (for cars with telephone) $10
NOS replacement antenna mast (for cars without telephone) $10
w124 HVAC switch over valve $20
NOS transmission filter 126 277 0295
NOS m103/m104 rear main seal 017 997 7447 $7
windshield washer pump 124 869 0221 $3
NEW in package w124 headlight seals 001 826 3480 $5 (for 2)
NOS M103 spark plug ends and boots 000 159 2842 $25
NOS Distributor Cap 103 158 0002 $25
w124 balljoint (NEW) 124 333 0327 $10
M103 valve cover gasket 103 018 0421 $5
tranmission pan gaskets $5 each
M102 flywheel/clutch assembly $50 (pics are above)
w124 wagon factory roof cross bars $40
Discussion Starter #22
LIST UPDATED 7/29/11:
List updated 7/25:
2 w124 horns $5
NOS transmission filter 126 277 0295 $5
received the filters today, very well packed thank you!!
Discussion Starter #25
Here's a new update new stuff will always be put up top:
w124 wagon OEM doggy barrier/cargo cover in GRAY $100 SHIPPED
w124 aftermarket driver's side clear corner $5
2 w124 horns $5
Discussion Starter #27
R107 hardtop lock set perfect chrome (cap for one side only) - $25
2 w124 horns $5
What size clutch is that flywheel? 9"?
Is this the whole piece I have one in both wagons, but for $100, I'd shelf one. :) More info please! :)
Discussion Starter #31
8 1/2" IIRC.
PM going outbound.
Discussion Starter #32
list updated!
2 w124 horns $5
aftermarket transmission filter 126 277 0295 $5
Could I get the info for the r107 locks. Do you have the fronts and the rears? You only have one chrome nut for the rear lock?
mb380
Discussion Starter #36
mb380
More info along with pictures sent in PM as requested. :)
Do you have a purge valve(MOT) for a W124?
Would you mind getting a part number for that? I've never heard of a purge valve (unless you're calling it something else) here in the US.
Thanks!
i am looking for 300TD wagon or sedan 250TD will do too turbo even better...
gasoline might do as well but depends on the condition... 92-95 i think
21 - 38 of 38 Posts
