Can you not use the little skeleton key that comes out of the end of your key FOB to unlock the trunk (never heard of that failing) and then put a low-amp (2amp or less) trickle charger or battery maintainer on the rear battery?
It will take awhile but that will re-charge both the rear and then the front batteries, the same way it maintains them both if you hook a battery maintainer to the rear one. That works on dual-battery Jaguars anyway and I believe it should work fine on one of these as you can use a maintainer on the rear battery to keep both batteries up and the trunk always opens with the little skeleton key that pulls out of the end of the key FOB since that's totally mechanical function and requires no power when opening the trunk with that method.
It's gonna be slow (like 8-24 hours if both batteries are totally dead) but should work. As I have came to understand it the front battery is also just a starting battery anyway, your rear battery is what makes your door locks work so it sounds like your rear battery is also dead.
Someone please correct me if I'm wrong but I believe I am correct.
My 03 Sl500 sat in the driveway too long and the front battery is dead. The car is locked and I m unable to unlock it even with the spare key. Anyone has an idea how I can unlock the car?. Thanks
