All,
As some of you may have read in our section's what did you do to your Benz today thread, my 190E has an interesting flaw. Upon attempting to replace the engine and transmission mounts, I found that the tail (output) housing on my 722.3 transmission has sheared next to the mounting point (see pictures). In an attempt to repair the issue, a bracket was made and holes were drilled into the remains of the attached transmission mounting flange, and 1 hole was too deep and penetrated the parking pawl fluid reservoir.
The hole was plugged, but I view this as a temporary fix as you can feel the transmission moving around in the car under acceleration and braking. I initially said that I was going to swap in a manual trans, but M103 flywheels are cost prohibitive (can only find 2.3 5-speeds here in South NJ), and my time is better used on other activities. The transmission shifts wonderfully and is probably the only part of the car that was treated well during the car's entire existence, so I will be replacing the output shaft housing with a good used unit.
Below I will document the steps to remove the exhaust, driveshaft, and replace the broken casing with the transmission installed in the vehicle, and of course how to put it back together. The car will also receive new flex discs, and the new housing will be treated to a new output bearing and seals, and possibly a center carrier at my discretion.
Status as of Today, 7/8/2017
Went to the junkyard today and attempted to pull a casing off of a 2.3 8v, stopped only because I ran out of time and was exhausted after removing everything in my way. Got home and realized that the 2.6 uses a flavor of 722.3 and not the 722.4. The same yard has a 300TE as well but I cannot remember whether or not it is 4-Matic but I'm going to say it isn't for now and go back to the yard and pull the case off. If for some reason I can't take just the case, I will end up owning the whole transmission which I'll either melt down the case of to make stuff with or scrap the whole thing, either way I think I'll end up heads up since a reman output case is $190 (how much is a pick-n-pull really going to charge me for a 25 year old transmission??)
Enjoy the photos, one of them shows how far I got with that 2.3 trans.
