Anyone can shed some light how to safely remove the broken stud holding the mirror to its arm? Mine's head shredded off when i tried to unscrew over tightened screw that prevented the mirror from any kind of movement.
Door mirror. The head holding the spring that prevents the mirror from moving in the wind has shredded off.Windshield mirror or door mirror?
Is there some kind of thread lock in there that's why it's so hard to unscrew the remaining stud?center punch the end and drill it out. or if there is any still sticking out cut a flat across and use a screw driver after soaking with kroil for several days.
heat helps a lot, but with chrome on it that wont work.
the correct machine shop can burn them out with special equipment.
