I bought a 1999 clk 430 about 3 months ago. One of the things I corrected was the broken door pull (upper) along with door check straps. I used the DIY door panel removal guids from the forums. For the handle, I took the 'cover part off' then took the hande off the door panel and used expoxy and thin metal nails to reinforce my fix. After 15 min hobby epoxy had dried I replaced. The epoxy and nails are not seen when the cover goes back on, or felt from the back of the handle.
