1 - 9 of 9 Posts
1993 SL600, 2000 BMW 528, 1993 BMW 850, 2007 Lexus GLX 460
Does anyone know of where I can get a replacement instrument cluster glass for my 93 SL600? Or does anyone have a dead cluster that wants to sell?
The previous owner cracked mine and I would like to replace.
1999 SL500 Sport, Black Opal Pearl, Helios Leather, Pano roof, AMG Aero2 18"Split Rims, Rear Seats
W124 E280, R129 SL500, BMW 525i E34
if only the plastic is broken, you can buy for that part, also it's the same part as W140, cost abut $100.00
Also when inside is dirty, do not use water or any detergent, because the inside clear plastic is covered by anti bacteria. Jut wipe it off by soft dry cloth
1995 SL 500 2017 AMG GLC 43
I just checked the MB Electronic Parts Catalog (EPC-net Online) for my SL and a separate glass is not listed. If it does exist as a separate part, I'd recommend going to the dealer to see if they can special order it for you.
Discussion Starter · #9 ·
Cluster Replaced! Some notes
I just purchased an excellent used cluster lens from a member on this forum. It was in excellent shape. I have a couple of notes for anyone doing this in future. I believe the best way to remove the cluster is by removing the bottom knee bolster trim (the trim under the cluster). Then you simply (and carefully) push the cluster out from the back with your hands. I was talking to the parts guy at the local MB dealer when I was buying some replacement cluster bulbs and he told me even the MB service techs have been known to crack older clusters by using the mercedes hook tool. When replacing the cluster you are replacing the entire lens and black shroud which makes up the front of the cluster (not just the front clear lexan). You will need to pop the clips holding the two pieces together and you will need to remove 2 small torx bit brass screws at the top to get the two pieces apart. Thanks to all who posted!
Shaun
1 - 9 of 9 Posts
