313 4x4 ,E320 CDI X 4,A160,A170 CDI ,W123,420 SEL,S420 L,420SEC,230,SLK230K, C180 ,C200,C230K, C230K
A common problem on all mercedes Cdi engines.
I can remove and replace the broken glow plug without removing the head.
The injectors do have to come out tho, so anyone interested please feel free to contact me.
Seized Injectors removed
Broken Glow Plugs removed
Ball joint replaced on site
Start error repair
New & used Ecu's
Abs problems Solved
Limp home solved
2003 sprinter 2500
2003 sprinter 2500 limp mode past 40 km/h
Hello, I am new here, I saw some info you have sent & may be able to help me.
I have purchased a 2003 sprinter 2500. Its known history; new ecu, new high psi and low psi fuel pump, 1 new injector.
I am a mechanic . No codes ( I have icarsoft MB 2).
Unit will start, run has power $ will shift through up to 3 rd gear .
Any time speedo reads 40km/h unit will go limp mode/ dead pedal.
Help?
Kendall
