1 - 1 of 1 Posts
1999 E320 Wagon
Clogged Cat?
My teenage son's 1999 E320 wagon blew the driver side diverter valve off its mount due to a missing mounting screw and extraordinary back pressure from the exhaust. the subsequent damage of exhaust gasses has melted the wiring harness carrier and burnt back some insulation on the #4 cyclinder fuel injector elect. connector. I made a steel plate and gasket to cover the missing diverter valve, but now the entire bank of cylinders 4, 5, and 6, are throwing OBD misfire codes and shut the engine down when throttling up to 2000 rpm or greater.
The car appears to run fine at idle without misfire until I throttle up. I did get a misfire when shaking the wiring harness. The vacuum hoses have been replaced now. The car had a temporary loss of power and seemed to recover just before this incident.
Do you suspect an exhaust problem. Where do I begin? I just found the replacement part on PartsGeek for $165, but I want to be sure that this will solve the problem before throwing money at the car. The car has many other ailments which appear to be less serious, but if this problem requires a large cash infusion it may get parked indefinitely.
:confused:
1 - 1 of 1 Posts
