Finally got the last damaged puck off by breaking off parts of it with a woodworking chisel. Got 4 new pucks on there now. I started taking the shift lever off inside to look at the P1856 issue, but it looks like removing the shift lever assembly will require removing some connections from underneath the car. So I thought I would get the car up on jack stands since I'll need to remove the transmission pan to get at the conductor plate for the 0705 code.
I could not find the "puck" for the central front lift location. The closest thing I could see is this
But this is recessed from the body belly covers, and it doesn't look very thick. If I draw a line running between the two front wheels, I don't see anything that protrude out.
If that central lift puck is missing, would I be able to jack up the front one wheel at a time using this metal piece? One side of the car is right up against a wall and I don't think I have enough clearance to use the factory jack from the side.
