My ML430 has the dark privacy glass which makes it difficult to see when backing up at night. Also, people tend to zoom on by when I am backing out of a parking spot. Replacing the standard 21 watt type 1156 backup (reverse) lights with brighter bulbs should help in both cases.
I have read a few snippets here and there on this subject and this is what I have so far:
1. The 50 watt replacements are possibly overkill and run the risk of heat damage if one remains in reverse for an extended period of time.
2. The 35 watt type 796 halogens are interesting but I am concerned that a halogen bulb will have a hotter base temperature than a standard bulb. Is there a risk of charring the light assembly?
3. The 28 (29?) watt type 3497 bulb seems like a safe choice. Is it bright enough to make a difference?
There is a problem with the 3497's as some of them are spec'd at only 21 watts (like the ones from Sylvania). This confusion is confounded by the fact that the manufacturers do not list the wattage on the product packaging.
Who has actual experience with any of the three options above? I was going to try the Wagner 3497 bulb sold by NAPA Auto Parts, but again the wattage is not indicated on the packaging.
