1 - 1 of 1 Posts
do most of you think that your stock 'braking power' is sufficient??
i'm asking as i've just changed my front brake pads....i installed Textar's (oem units). but even before that if i used to go out and purposely do brake tests they seem fine....but last night i had to do a emergency braking procedure and they seemed completely insufficient. i do realize that instead of 25mph during my test runs i was doing perhaps 45mph....but it didn't seem the brakes were strong enough.
secondly, does everyones abs come on with a lot of 'grinding' type sounds.....my dealer says its normal.
also, is the 300se/l equipped with the same spec discs / pads as the 420 or 560's?? i'm running stock 15" wheels so if there is a difference, i should be able to upgrade to the 560's specs w/o any issues.
thanks again....sorry for the rather long-winded story here!!
1 - 1 of 1 Posts
