380SL, Jag F-type
My 99 R129 brakes are audible (groan, not squeal) and grabby at low speeds when wet and cold. Very difficult to come to a completely smooth stop, but not a safety concern. Without taking anything apart - things look fine. I am thinking PO neglected fluid changes or let pads run too low and I have pitting on the front caliper pistons. Before I start disassembling - is this behavior normal for R129?
94 SL600, 89 Jag XJS conv, 85 Daimler Princess, 97 993 63 Avanti 16 Lincoln MKZ hybrid 16 Silverado
Benz has pad sensors and other "nanny" type systems. unless your car has been altered you will get a message about pad wear.
I have several vehicles that with renewed pads react differently.
Some pad material composition is grabby, others squeal. Wet is always another world of friction dynamics.
Good luck on your search
91 500SL 37k,90 300SE sold, 91 300E sold , 92 300E137k ,02 Kia Sedona ,I know..... its a Mini van.
I can't tell you how many times I've had brakes apart trying to find the problem,on high mileage cars,hard to figure it out,always end up replacing everything.good luck.
