1 - 20 of 20 Posts
1996 S-500 white
I'm Doing Brakes On My 2002 SL 500 , But I Only See 3 Wear Sensor's On My Car 2 up Front One On Each Side And In The Rear There Is Only One On The Right Side ,, And I Don't See A Place For One On The Left Side Rear The Bracket IS There But No Hole In It For One ,, Is That Right ,, Only 3 On The Car ???
thanks
Joe :Smoker:
07 SL350, 14 BMW320, 05 SLK and 4.6 MGBV8
Some cars only use two - one on the front and one on the rear. The theory being that if one side's pads hit the sensor, then the other will be worn down as well, and as both sets should be changed together, why bother with another sensor.
I cannot remember if mine had two or one on the rear. The 230 has two...
If your car is to be well serviced, then you will never need the sensors as you will change the pads before they get that low.
Worry about having the front ones working, they are the important ones.
MB SL600, MB 380SE, Suzuki Grand Vitara, 38' Chris-Craft, Volvo V70XC, and my own two feet...
thanks
Joe :Smoker:
Yeah, you got it right! It's only 2 in front, and 1 in the rear. That's how it's supposed to be. :thumbsup:
Are you going with ceramic pads and silver arrow rotors?
1996 S-500 white
Yes Ceramic Pads,, Dimple Drilled And Slotted Rorors, And 2 Rear Cal, And 4 New S.Steel Braded Hoses, And New Hardware pins and all.Flush Out Old Brake Fluid :D
Here Is Where I Got Them From
Brake Performance - Slotted and Drilled Brake Rotors
Thanks For Your Info
Joe :Smoker:
You will be AMAZED at the difference the SS lines make. They feel like *real* brakes after that, instead of the too-soft spongy feel you're used to.
1996 S-500 white
Discussion Starter · #6 ·
What Do You Think Of The Rotots That I Picked Out ???
And My Wife Will Be Amazed On How Much Money I Am Saving By Doing It All My Self :D
I'm Also Greasing My Front Wheel Bearings :D
Joe :Smoker:
Joe :Smoker:
They look nice!
I have always wondered, what's the advantage of "dimpling" the rotors instead of drilling them? Must be some logic behind it...
1996 S-500 white
Discussion Starter · #8 · (Edited)
They look nice!
I Have No Idea Also ,, Only What I Read,
Ant This Was There Best That They Had.
Here Is What They Write About Them
DIMPLE-DRILLED & SLOTTED
Partially Drilled Holes Dissipate Heat without Sacrificing Strength
But I'LL Be The First To Find Out :D
Joe :Smoker:
http://brakeperformance.com/site/br...664_33704_36100_36101_84320&dv=0408&ad=google
Lifetime Warranty Against Warping and
Defects in Materials & Workmanship
PREMIUM DIMPLED & SLOTTED (BLACK)
FRONT SET - TWO (2) ROTORS #RB-35046
FREE SHIPPING • FREE BRAKE PADS • LIFETIME WARRANTY! LIST: $550.49
$366.99
CROSS-DRILLED & SLOTTED (BLACK)
REAR SET - TWO (2) ROTORS #CB-35030
FREE SHIPPING • LIFETIME WARRANTY! LIST: $247.94
$165.29
2000 Obsidian Black Metallic Mercedes SL 320 V6 (SOLD) 2012 E 350CDI Cabrio 265 PS
Joe :Smoker:
That's what I heard too but I went for drilled anyway because in case of rain they seem to dry faster and collect less water or at least that's what I understand using drilled rotors. Please correct me if I am wrong.
Cheers.
Anything done to increase the 'exposed' surface area of the disk rotor will help cooling. So drilling gave the most surface area but also weaken the disk (slightly). Dimple also increase the surface exposed to air and it does not weaken the disk. Slotted disk provide channels for water to 'spin' out, and also increase the surface area.
1996 S-500 white
Discussion Starter · #11 ·
RKH:
Good Answer, I Got Dimple/Drilled/Slotted All In One :D
· Greek God of the R129
SL500-500SEL-190E
If you are racing you may crack the drilled rotor.
Otherwise you are safe.
The idea is to have clean pads, and throw the gasses out.
And like Mick/ msbarsi says, they are good in the rain.
Hmmmm.
I got to go. No I better run, I think I got some gas. ;)
I know I am going to get in trouble with this. LOL.
S*T I have them, & love them.
Look cool too. ;)
Regards.
aam.
1996 S-500 white
Discussion Starter · #13 ·
Hmmmm.
Look cool too. ;)
Regards.
aam.
AAM:
I Posted This In The R129 Forum
Do You Have An Answer For Me ???
Joe :Smoker:
BRAKE FLUID ?? I Got Castrol GT/LMA SYNTHETIC For ABS, Disc,And Drum Brake System Exceeds DOT 3 & DOT 4 Specs NEW Formuler.
Is This Ok To Use In My 2002 SL 500 ?
I'm Flushing Out All The Old Brake Fluid
Let Me Have Your Thinking On This Fluid
Joe
P. S. I Looked All Over The Forum And Can't Find Anything On Brake Fluid !!!
Joe I think any known brand of DOT 4 brake fluid will do the job. I have always been advised not to use DOT 5 but I've never understood why even if I've always thought about it.
I know it's not that much of advise but that's all I know about brake fluids.
Hope it helps.
Cheers.
In a nutshell, DOT5 is silicon-based fluid, and DOT3 and 4 are glycol-based fluids. The main factor in brake fluids are their boiling points. DOT 5 is generally a better product if you don't change your fluid annually or biannually, because it doesn't attract water like 3 and 4 do.
Problem is, silicone is a "softer" liquid, and is around 2X more compressible than gycol is. So the pedal feel with DOT5 might not be as firm as with 3 or 4. But at the same time, it maintains much higher operating temp capacity, because it doesn't pick up the water that SOT 3 and 4 do, and the feel will be a lot more consistent over time. So like anything else, it's a trade-off.
Generally speaking, if you aren't tracking the car, and you stay on top of your maintenance (e.g. don't mind changing the fluid), then you'll probably get the best performance out of using DOT 4 and changing the fluid once every year or two. If you're one of those people who never change the brake fluid, then DOT5 will work best for you.
1996 S-500 white
Discussion Starter · #16 · (Edited)
Hope it helps.
Cheers.
Well Im Going With Castrol GT/LMA SYNTHETIC For ABS, Disc,And Drum Brake System Exceeds DOT 3 & DOT 4 Specs NEW Formuler
I Never Had Any Brake Fluid Problems, And Hope I Don't
I'm Going To Flush It All Out With A Pressure Pump So I'LLGet It All Out Along With The Air.
This Is The Pump I'm Going To Use,, You "GOT TO LOVE E-BAY"
Joe :Smoker:
Motive Products 00100 European Power Bleeder JEGS
Power Bleeders
Works on most European cars, including Alfa Romeo, Audi, BMW, Fiat, Mercedes, Peugeot, Porsche, Renault, SAAB, Volkswagen, Volvo, and all other cars with 45mm threaded hydraulic fluid reservoir caps (Adapter #715-1100). Comes with everything you need to bleed your hydraulic brake or clutch system.
Bleed Brakes Like the Pros!
The Motive Products POWER BLEEDER is the number 1 selling DIY pressure brake bleeder. The POWER BLEEDER operates just like the professional mechanics' tool -- at a fraction of the price.
Now you can bleed hydraulic braking and clutch systems like the pros.
Easy one-person operation means you won't need to ask a helper to pump the pedal while you open and close the bleed valves.
Corrosion-proof design for years of maintenance free service.
POWER BLEEDER hand pump works anywhere - great for the home, shop, or track.
SL500-500SEL-190E
AAM:
Joe :Smoker:
Joe
Hi Joe.
Thanks for asking my advice.
But as usual it comes with plus. ;)
I think any good quality brake fluid that meets dot 4 and manufacturers requirements is OK by me.
I am not a Mercedes parts fanatic, I go for the after market but with careful choices,
I go for the Mercedes parts makers, but with out the star mark on them.
I go for Bosch on electronic parts, Febi on fluids, Bilstien struts. Etc.
As long and it mixes with the existing fluid/
I also have used Castrol dot 3-4 with no problems.
Hmmmmmmmmmm.
You mentioned that you have posted it in R129.
( That's us.)
I wonder where else have you posted it in, may be in one of the P#$% sites? Haha.
You bad boy you.
I would not install the silicone stuff in............
It is OK for fun clutches, tits and nipples.
( Oops, did I misspell something? )
But I will keep it away from ABS and the suspension mechanics.
Regards.
aam.
PS.
Like msbarsi and Chris have said, I go along with them.
1996 S-500 white
Discussion Starter · #18 ·
Hi Joe.
Hmmmmmmmmmm.
( That's us.)
You bad boy you.
Regards.
aam.
PS.
Well AAM
I Have No Idea Where Else I Posted This Question I Have CRS Real Bad It's A Sickness :confused:
But I Do Know I'LL Use DOT 4 :thumbsup:
See My Pump I Just Got ?? That Should Get Out All The AIR , Even The Hot Air Ha Ha Ha
Tell Me If You Like My New Computer Ok I Built It Myself :thumbsup:
Here It Is LOOK
Joe :Smoker:
1996 S-500 white
Discussion Starter · #19 ·
Hi Joe.
Hmmmmmmmmmm.
( That's us.)
You bad boy you.
Regards.
aam.
PS.
1 - 20 of 20 Posts
