1 - 20 of 64 Posts
Hi there folks!
I just completed brake pads and sensor replacements on 2003 SL500. I replaced the worn stock pads with Akebono ceramics on all four wheels and installed brand new sensors. Now I have a dash error message in white text that will not go away.
The message says, "BRAKE - Service Brake! Visit Workshop". I thought this would go away after a few miles (as did the "worn brake lining" message), but I have driven almost 200 miles now and it is still there.
Any ideas how to get rid of the message?
Discussion Starter #2
Apparently no one has experienced this before, since I did not receive any response. However, I can almost guarantee you would because I took the car to the dealer and the SBC Hydraulic Unit was replaced. Apparently there is a ten year factory warranty/recall on that unit.
Dealer Diagnosis Print out:
CUSTOMER STATES "SERVICE BRAKE - VISIT WORKSHOP" MESSAGE IS ON.
INSPECT BRAKES.
FOUND SERVICE TIME OF PUMP HAS BEEN EXCEEDED.
ATTEMPT TO UPDATE SBC SOFTWARE.
PROCESS WILL NOT BE ALLOWED.
SCREEN SAYS "SERVICE TIME EXCEEDED - REPLACE SBC HYDRAULIC UNIT".
REPLACED SBC HYDRAULIC UNIT.
BLEED BRAKE SYSTEM.
PROGRAM AND ROAD TEST.
PARTS:
005-431-97-12 HYDROPNEUMAT
000-989-08-07-01 BRAKE FLUID
PARTS AND LABOR UNDER FACTORY 10 YEAR SBC UNIT WARRANTY.
Thanks for giving a shout out.. I would have thought it needed resetting or some sort but I haven't come across this but thank you as if it does i'll know whats up with the thing!..
Thanks for the post egwu :thumbsup:
I also got a malfunction displayed on the left in a 1" big bold white font "Brake " and " Visit Workshop ". :bowdown:
With no advice from within the owners manual and without an extended warranty on my 2003 SL500 , I was prepared to bit the bullet by having the dealer diagnose the warning . I was correct in thinking that it was the SBC pump failing. Besides the warning text , the only indication was that the brake fluid level was rising and lowering like the ocean tides .
Needless to say , I was extremely pleased to discover that M/B has warranted the SBC unit out to ten years from the manufactured date .
Yes, I think Mercedes really took it out of Bosch's hide to extract this extended warranty. Poor quality of this part really hurt Mercedes' reputation, but of course when there aren't little problems it's a great system.
can you elaborate on this error. My light just came on today and it was not red screen just a normal message with the work BRAKE in the left window followed by a Brake Service Visit Workshop in the right screen.
Was this part under full warranty? did you have to pay for the Brake fluid flush?
Reluctantly, I brought my car to the dealer to diagnose this problem. They confirmed that it was the SBC pump and that it was covered under warranty. They wanted to charge me for a brake flush. I declined since I can do that myself for a fraction of the cost.
No more error message and it did not cost me anything.:bowdown:
I love this benzworld, I was ready to open up my wallet until I read up on the failure here on this site.
Hi, I do have SL 350, 2005, just got the car out of workshop, I had the same problem with SBC pump, which is under warranty for 10 years. Workshop did programming and problem disappeared. But they told me that I need to replace the front brake disks, due to the thickness is 25.5mm instead of minimum 26mm. I would like to ask if you know what is critical thickness for front brake disks? Do I really need to replace them now, or I do have more time? :) Here they cost about 1 000 USD for front pair. Thanks for advise.
Unfortunatly, they are correct. According to the service manual, the rotors are supposed to be replaced when you replace the brake pads. So if you had replaced the brake pads, you should have replaced the rotors as well.
There are alternative places to purchase rotors, however, I am not sure if they ship to Dubai.
Dear Mkirincic Thanks a lot for your message. I will try to find ones in US through my friends, due to in official MB workshop rotors cost 2 000 USD, alternatives suppliers can provide for 1000 USD, anyhow I will change them, just wanted to confirm with experienced people. Here when you bring the car older than 3 years to MB workshop they give you a list that you need to replace half of the car :)) Thanks for advise. :)
Had a hairline crack in my front left rotor. Took it in to M/B. They put on fresh rotors (both front) and pads for $470. (2003 SL500).
I'm having a little problem with my 2006 ml350, 40k miles and warranty just expired..*Long story short 'brake wear visit workshop' came on had the front pads changed with sensor, also did rear sensor, all brake pads are fine... But now the 'brake wear visit workshop' comes on when I'm driving, sometimes when I *hit a road bump... *This disappears when car is turned off and happens again and again ...Dealer says its the brake sensor harness but they haven't checked yet... It seems they're guessing and I don't want to throw money away, the want to charge $400 to do harness, yea and if its something else.??.
What do you think it is? Thanks
INSPECT BRAKES.
BLEED BRAKE SYSTEM.
PARTS:
Just had the exact same thing pop up on my 2003. After reading this post took it to the dealer. The SBC motor and pump are out and it's covered 100% by the dealer. They even gave me a ride home and are sending a car for this this afternoon when it's finished. My car is 9 year and 9 months old so I barely made it on this 10 year warranty.:D
Chalk another one up for the MB forums...this would have been a $5000 repair if I had to pay for it.:crybaby2:
Same problem with my 2003 500SL; however, the white turned to RED and the brakes completely failed. I'm past the ten year and have the car at an INDY and shutter to think of the bill. Luckly no one hurt and the auto still in one piece.
Seems like you may have found the one honest dealer in the USofA, the repair cost on your brakes looks good to this olde fat boy.
Update: My INDY informed me that the SBC Pump was the problem and I had twenty days left on my warranty. I took the car to Mercedes and they claim they have not found the problem. I think they are trying to delay until the warranty has expired. Suggestions??????
Discussion Starter #17
Run back to your indie and ask for a print out of the SDS (diagnosis) report. You could also capture a screenshot of the SDS report with a cellphone camera or something. Take that back to the dealer as evidence. And when they are done replacing it, ...tell them to go screw themselves. I too think they are stalling for time. Even so and it becomes evident after the warranty expires, they still can't escape the fact that you reported the malfunction BEFORE the expiration date.
Luckily I had mine replaced under warranty by the dealer a couple years ago.
Brakes
That is exactly my plan for FIRST THING Monday morning. This dealership quoted $ 2243.00 to repair my tire pressure sensors, ordered the parts on line from www.O&EWheelsllc.com - $ 168. and had them installed and the tires filled with nitrogen at John Miller Tire Company $ 20.- total cost $ 188.00. I saved $ 2000. and did not have to deal with the Stealership - Priceless. I will update this post until the issue is resolved. Thanks for all the responses.
Brakes
Bottom line, The MB Dealership performed the following service:
Parts 008-431-98-12-88 REMAN HYDRAUL Warranty
008-431-98-12-70 CORE HYDRAUL Warranty
000-989-08-07-01 BRAKE FLUID Warranty
000-430-07-12 OPERATING UNIT $ 1290.
LABOR 398.81
SHOP SUPPLIES 27.92
TAX 143.55
I don't know if this was a square deal or not, I plan on taking the work order to my INDY and find out how badly I got taken.
My INDY stated that the dealer had replaced both parts and while he was not able to verify that I needed an operating unit that the price was fair. I totally distrust the dealer but will have to accept this repair and hope I never have to return to the Stealer. I do trust the INDY.
1 - 20 of 64 Posts
