1985 190e 2.3
Hello,
I have a 1985 190e 2.3 and am having problems with the brakes to the tune of 90-95% brake failure.
Symptoms:
No signs of fluid loss,
Bleeding brakes reveals very little pressure at front, none at back.
Front brakes are only a little grabby
No help from the rears at all except for hand brake.
Pumping the brakes makes no difference whatsoever.
From the described symptoms... can someone tell me if I am looking at a failed brake booster, master cyclinder or both?
Thanks for whatever help comes. :)
JT
1985 190E(SOLD 04/14/11) - 1986 190E - 1986 190E 2.3-16
Master cylinder is shot for sure. Typical symtoms.:thumbsup:
1985 190e 2.3
Thanks for confirming what I pretty much suspected...
I've ordered a Metelli replacement.... Italian part in German car, I hope they can get along. LOL!
From looking at the Haynes manual and the easy accessability of the part, I am tempted to do this one myself.
For any of you who have done this yourself... how long did it take you and were there any "gotcha's" that I should look out for?
93 190E 2.6; 82 300 SD Turbo
Its fairly easy and straight forward, you just have to make sure you bench bleed the new master cylinder.
1) remove fluid from old reservoir
2) remove reservoir
3) remove brake lines from old master
4) remove old master from booster
5) bench bleed the new master
6) install new master
7) install brake lines
8) install reservoir
9) fill
10) bleed all 4 corners.
