1 - 1 of 1 Posts
Dealer's response:
.....After all tests made, we are now fully aware that the noise off your complaint has to do with the operation of the entire braking front ... The design of this set ...... cause a metallic sound, (more!) or less audible .......... to actuate the braking system, the fluctuation (sliding) of the square pad .... may produce a slight rebound, causing the wafer bump against it, causing a metallic noise .....,..............'re in the presence of noise which is so related with the current configuration of the product ........................
"That is no solution and no peace for anyone who drives the car."
1 - 1 of 1 Posts
