1 - 9 of 9 Posts
Anyone know the good break pads for W203 that low dust but still good stopper.<br> My rims are all monoblock V 19' but i don't know why there are so much dust on my both front rims.<br> I have to cleaned them everyday after work.<br> I really need any suggestion which break pads name should i get ? I think i can't stand the stock's break pads anymore.<br> Thank you.
Should i have to change Disc Brake also? if...
If i use breake pad that different from the stock, do i need to change disc brake also? If not Will it be damaged ? Should i have to change all 4s?or just Front?
Re: Should i have to change Disc Brake also? if...
no, just the pads will work. they will need time (300-400miles) to 'bed' properly. unless rotors are badly scored, shouldn't need to turn them either. if you go w/aftermarket pads like EBCs, DO NOT just put them on the rear, but you can put them on just front or all 4 corners. rear wheels will lock up very easily if you just do rears!!
1 - 9 of 9 Posts
