ML 320 01'
It happens only while backing up. Is this a rear brake sensor warning or something else? Thanks.
· Member
'00 ML320 Elegance
ed - 3/12/2005 6:16 PM
It's the warning...when my pads started running out, initially the warning only flickered on while I was braking while backing up. However you'll find that within a short period, they'll start coming on when you are driving normally. Time to start considering/budgeting for a pad change![:)]
ML 320 01'
Thanks for your reply. Yes beeping occurs when those 2 lights comes on. I haven't inspected the pads yet but I would assume that it will probably be the front pads going out first, right?
